Adds and configures SNMPv3 target parameters.
| hex_param_name | Specifies the parameter name associated with the target. The value is to be supplied as a colon separated string of hex octets. |
| param_name | Specifies the parameter name associated with the target in ASCII format. |
| hex_user_name | Specifies a user name. The value is to be supplied as a colon separated string of hex octets. |
| user_name | Specifies a user name in ASCII format. |
| mp-model | Specifies a message processing model; choose from SNMPv1, SNMPv2, or SNMPv3. |
| sec-model | Specifies the security model to use. |
| snmpv1 | Specifies the SNMPv1 security model. |
| snmpv2c | Specifies the SNMPv2c security model. |
| usm | Specifies the SNMPv3 User-based Security Model (USM). |
| sec-level | Specifies the security level for the group. |
| noauth | Specifies no authentication (and implies no privacy) for the security level. |
| authnopriv | Specifies authentication and no privacy for the security level. |
| priv | Specifies authentication and privacy for the security level. |
| volatile | Specifies volatile storage. By specifying volatile storage, the configuration is not saved across a switch reboot. |
sec-level—noauth.
non-volatile storage.
Use this command to create an entry in the SNMPv3 snmpTargetParamsTable. This table specifies the message processing model, security level, security model, and the storage parameters for messages to any target addresses associated with a particular parameter name.
To associate a target address with a parameter name, see the command configure snmpv3 add target-addr.
The following command specifies a target parameters entry named P1, a user name of guest, message processing and security model of SNMPv2c, and a security level of no authentication:
configure snmpv3 add target-params P1 user guest mp-model snmpv2c sec-model snmpv2c sec-level noauth
The hex_param_name and hex_user_name parameters were added in ExtremeXOS 11.0.
